see pics for explanation if you have a worn 3/8" flex head socket may help instead. Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Images (Click to enlarge)
Sep 4, 2016 at 1:23 AM
2CP-ARCHIVES
MEMBER
What tools are needed to change a starter in my xj8 1999 jaguar
Aug 1, 2019 at 11:50 AM
(Merged)
✓Experienced Mechanic
You will need a socket wrench with an extension and regular box end wrenches to remove wiring from the starter and battery.
(Merged)
FERRY1980
MEMBER
1 POST
where is the starter located
(Merged)
DAVE H
located on right side of engine block
(Merged)
KELLYJROBERTS
MEMBER
1 POST
Hi there,
Where is the Jaguar starter? I heard that I have to change the started laying under the car and is difficult. Is this true? Any tips?
(Merged)
DOCFIXIT
You are right under car could be considered difficult and dirty job. That's why we charge $90 hr labor.
Only tip I can give is use jack stands and car cold your going to be real close to exhaust pipes.
