clutch master cylinder?
168,000 MILES • 4.2L • V6 • 2WD • MANUAL
ONEFALCON07
I have been trying to figure it out for a week now and even bought a Hayes manual, it was no help. I cannot get the push rod out of the housing where it goes through the firewall and into the clutch master cylinder. it will not pull out. I do not see any clips holding it in and the dealership said if I brought it there it would be a half hour fix. can someone please help me out here?
Sep 17, 2017 at 11:02 AM
STEVE W.
  • 15,394 POSTS
There is a retainer inside the master cylinder that holds the push rod in. It is there so the push rod cannot pull out if the clutch pedal is released faster than the master cylinder can return. To get to it you need to remove the master cylinder from the mount.
Sep 17, 2017 at 6:43 PM
ONEFALCON07
that is what I was afraid of. I have never removed a master cylinder before, but thank you.
Sep 17, 2017 at 10:46 PM
  • 55,649 POSTS
Please use 2CarPros anytime, we are here to help. Tell a friend please.
Cheers, Ken
Sep 19, 2017 at 3:58 AM
BRIAN K CONNER
  • 35 POSTS
How do I know when the clutch master cylinder is going bad?
Mar 24, 2021 at 4:55 AM (Merged)
PATENTED_REPAIR_PRO
  • 1,853 POSTS
One good indication is a leak coming from the back side of it leaking right down the center of the firewall or wherever it is mounted to.
A second might be is there is no leaks but the clutch pedal goes to the floor when pressed and the clutch not work.
TAYLORSINFLORIDA
do i remove the master clutch cylinder line all the way to the trans? i have removed the two nuts already at the firewall. how do i remove the line from the trans it i have to? 1995 f150 p/up
  • 31,937 POSTS
Hi there,
You only need to unscrew the pipe at the master cylinder, also you will have to undo the pin that holds the push rod to the pedal under the dash,
mark (mhpautos)
FORD1995
Transmission problem
1995 Ford F150 6 cyl Two Wheel Drive Manual
i have a 95 ford f150 i have replaced the clutch master cylinder three times the problem is that the rod that hooks to the clutch pedel keeps poping off ive replaced the clip but it dosent seem to help i cant see anything bent or out of alinment any ideas where to start to resolve this problem
  • 31,937 POSTS
Hi there,
take off the clip & drop off the push rod, feel for any sideways movement in the pedal, the pedal pivot bush & pin may be worn, check this next.
Mark (mhpautos)
