How to remove garnish panel from rear hatch door?
72,000 MILES • 3.5L • V6 • 4WD • AUTOMATIC
AVECCHIO946
The rear License plate lamp melted on the left side; the right side is still good. Purchase OEM replacement which is 2 lamps with harness. Lamps located in rear hatch garnish panel. I already removed the inner trim and 4 nuts of garnish panel inner bolts. When i went to outside and tried to lift the garnish panel off the rear hatch door, it did not seem to come off easily. Do i have to pry the top of garnish panel to release any clips? did not want to force i and break panel.
Apr 24, 2023 at 5:45 AM
  • 110,246 POSTS
I'm not sure what melted. Are you referring to the assembly that melted? If so, it is held in by two screws. See pic below.
If that is not correct, please take a picture of what you are dealing with and upload it for me to see.
See pic below.
Apr 24, 2023 at 12:33 PM
AVECCHIO946
The melted lamps are not the issue. I have to replace lamps with wire harness. Need to remove garnish panel on rear hatchback of 2014 Santa Fe. lamp harness feeds through garnish panel. after removing 4 nuts on inside of hatch back off garnish panel bolts. panel would not come off. I now see 2 nylon clips inside hatch back that are under garnish panel. any idea how to release these clips. Think after releasing nylon clips, the garnish panel will lift off.
Apr 25, 2023 at 5:44 AM
  • 110,246 POSTS
That isn't indicated in the manual. Is there a way you could take a couple of pictures and upload them for me to see? I should be able to help.
Apr 25, 2023 at 11:38 AM
AVECCHIO946
Hi Joe, in your manual, to remove lift gate garnish panel beside it saying remove 4 nuts off bolts that are attached to garnish panel, does it say anything about removing 2 nylon clips on the bottom of panel from inside of lift gate?
I'm going to try to remove the 2 clips with a screwdriver or needle nose plier.
Apr 26, 2023 at 1:25 AM
  • 110,246 POSTS
For some reason, they aren't even identified. Were you able to remove them and did it help?
Apr 26, 2023 at 1:00 PM
