removal of clutch pedal slave cyclinder
250,000 MILES
JEZ075
could you please explain the removal and replacement process and what also has to be disassemabled to replace the clutch slave cyclinder connected to the clutch pedal.pedal will only depress half an inch and comes to a complete stop.clutch operates mannually from the top of housing by hand,just not from the pedal.
Oct 28, 2013 at 6:29 PM
HMAC300
  • 48,601 POSTS
that is the master cylinder not slave slave is on clutch see instructions
Drain clutch fluid through bleeder screw. From inside of vehicle, remove cotter pin, washer and clevis pin. From engine compartment, remove fluid line and master cylinder mounting bolts. Remove master cylinder. To install, reverse removal procedure. Bleed system.
Oct 28, 2013 at 11:20 PM
