Removable key fob key
250,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
PEACH2571
  • 6 POSTS
My battery has died completely. I am trying to get a jump but can't get under the hood to get jump.. the removable key from the key fob does not work for some reason.. how do I get in the car now?
Dec 1, 2019 at 3:28 AM
  • 110,248 POSTS
At this point, it sounds like the only option is to have it opened using what is called a slim jim. It is a thin metal tool that goes between the door glass and the weather stripping. Once in, you have to find the lock linkage with it and unlock the door.
I don't know where you are located, but most times if you call the local police, they will do it for you as long as you have identification and proof of ownership.
Let me know if you get in to it
Dec 1, 2019 at 1:32 PM
