Remote will not lock doors
63,000 MILES • 1.9L • 4 CYL • FWD • AUTOMATIC
SLSREPDLS
I have just replaced the door lock switches (drive, passenger & console). Also replaced both relays in fuse panel by passenger floor board behind console panel. I still have an issue with being able to lock the drivers door via key fob. The unlock button works fine on fob. When I try and lock the drivers door the horn will chirp and alarm will arm. Alarm works as it should. Only the door actuator will not respond. It will however lock and unlock via the door switches. I hear a click high up in the dash for unlock, but not for lock when using remote. Any ideas please?
Feb 3, 2016 at 4:26 AM
WRENCHTECH
  • 20,758 POSTS
You're going to need a dealer level scan tool to access the Body Control module to determine if the BCM is seeing the lock request from the RKE and whether it is responding with the command to operate the lock.
Feb 3, 2016 at 8:13 AM
