Remote starter anti grind relay
226,120 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
1502WS
  • 6 POSTS
I installed a remote starter on my car. when i use the remote, the car starts but the starter keeps engaging. the instructions say install a anti grind starter kill relay. they say to install the relay, use the ignition wire on the steering column the one with 12volts only when starting. I don't know what wire to use. Can you help and tell me what wire to use so i can be done? And thanks for helping me with the parking light problem. I found a broke wire down in the harness.
Dec 16, 2021 at 1:40 PM
Good morning,
I attached a diagram for you of the system with the wire you need. I circled the wire for you.
Let me know if you have any other questions.
Dec 16, 2021 at 7:52 PM
1502WS
  • 6 POSTS
Roy, thank you for the help the remote starter works like a pro installed it. The relay works fine i can hear it click. The starter hits one time the car starts up starter stays in. thanks again.
Dec 17, 2021 at 2:36 PM
You are welcome.
Always glad to help.
Dec 17, 2021 at 7:20 PM
