Replacing the key fob that locks unlocks panics?
205,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
DOOB
  • 72 POSTS
Lost my remote start key fob. So how do I go about replacing the key fob that locks unlocks panics? And remote starts my truck. All I can find is lock unlock and panic only. All help is much appreciated.
Jun 23, 2025 at 8:18 AM
STEVE W.
  • 15,387 POSTS
Ford didn't offer remote start as a factory option on the trucks. You have either a dealership or other aftermarket unit installed. As such you need to drop the panels under the dashboard and see if you can locate the remote module box. Then look on it for a make and model and an FCC ID. Then you can look that up and see if you can get a replacement fob. Directed made a lot of the dealer installed kits.
Jun 23, 2025 at 10:41 AM
DOOB
  • 72 POSTS
Ok. Thanks a bunch!
Jun 23, 2025 at 12:42 PM
STEVE W.
  • 15,387 POSTS
Yeah it makes it harder but usually they tuck them up behind the driver's side and tap into the wiring. From there you should be able to get the info and search for the proper remotes.
Jun 23, 2025 at 2:16 PM
