Remote Start does not work when cold
2008 SUZUKI XL7
49,000 MILES
BDH062
My factory installed remote start does not work when it is cold (below 40 degrees). When you press the remote start button, the brake lights and parking lights flash once (normal) and then nothing happens. I think it might be a fuse, but cannot find the correct one.
There is a youtube video that identifies the issue perfectly:
http://www.youtube.com/watch?v=SLdY_re40Ls
Thanks
Nov 7, 2013 at 9:28 AM
HMAC300
  • 48,601 POSTS
check your battery in your remote it may be weak. if it starts warm but not cold its' not a fuse.
Nov 7, 2013 at 11:03 PM
BDH062
I just replaced both batteries in the remotes, and the same thing happens. Once the car is room, it will start via the remote start.
Nov 18, 2013 at 10:55 AM
HMAC300
  • 48,601 POSTS
then have a pro scan it to see what is wrong with it.
Nov 18, 2013 at 10:04 PM
