Remote start battery location?
60,000 MILES
PCAVINEE
  • 31 POSTS
This is my son's vehicle, and his car is equipped with a battery that the dealer said is under the dash that needs replaced. Do you have any pictures or info on this?
As always thank you. Mark
Mar 2, 2024 at 9:05 AM
  • 110,248 POSTS
Hi Mark,
I'm not sure I heard of such a battery. The remote (fob) has a battery, but it doesn't sound like that is what they are referring to.
I attached three pics below. Pic 1 shows the location of the remote function actuator module, but I don't believe there is a separate battery for it. Keep in mind, that is for all remote functions.
Pics 2 and 3 are the wiring schematic for the starting system. I read through it a few times and don't see anything indicating a separate power supply.
Let me know what symptoms your son is experiencing and if they provided any diagnostic trouble codes that may help me narrow things down.
See pics below. Note: The wiring schematic was one page. I had to cut it in half to make it readable for you. I did overlap the two so you can follow from one to the next.
Mar 2, 2024 at 2:50 PM
PCAVINEE
  • 31 POSTS
Thanks for your reply. The car has a special function where the car actually shuts off while at a red light according to my son. The dealership told him that there is a battery separate from the main battery that operates that remote section. I was just trying to see if it was something we could change out. Dealerships are expensive. I will call the dealership and see exactly what they are talking about. Thanks for your reply as always.
Mar 3, 2024 at 12:01 AM
  • 110,248 POSTS
I know there is what is called a PCM wake up signal, but I thought it used the battery under the hood.
Do me a favor. Let me know if this has the 1.5L Turbo or the 2.0L Turbo. I'll do some digging for you.
Mar 3, 2024 at 12:40 PM
