Remote locks stopped working replaced radio
150,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
DOODLE333
Stock/OEM key fob/remote locks stopped working after replacing OEM radio head unit with a aftermarket one that was plug and play. Also, cannot get the information screen to the program/activate the remotes even tried new one's.
Dec 26, 2016 at 9:16 AM
CARADIODOC
  • 34,414 POSTS
Put the old radio back in. You fell for one of GM's many customer-unfriendly business practices. The Body Computer is built into the radio to prevent you from replacing it when it develops a problem. They want you to be tied to the dealer and their two grossly-overpriced radio repair centers.
You can also consider searching for a radio relocation kit made specifically for GM vehicles. That will allow you to cut the speaker wires and run them to your new radio, then the original radio can be mounted under the seat, (or in the trunk of cars). That will let you retain the turn signal click, chime, door locks, and other Body Computer functions.
Dec 26, 2016 at 9:33 AM
DOODLE333
Everything seems to work correctly, the chime works, seat belt chime, signal clicks, and and came with the ONStar module (have not completely plugged in yet though) maybe after that it might work? or can I bring it to dealer and have them flash ECU?
Dec 26, 2016 at 10:01 AM
DOODLE333
If not I will just get a after remote starter with door lock key fobs.
Dec 26, 2016 at 10:04 AM
CARADIODOC
  • 34,414 POSTS
You are in an area now that I know nothing about. For mechanics, the days of being able to modify circuits and add stuff is long gone. The insane engineers have seen fit to hang an unnecessary, unreliable computer onto every single part of our cars, and a lot of that stuff has no benefit for the car owner. There are no denying airbags and antilock brakes are worthwhile, but there is no reason to involve two computers in blowing the horn. There is no benefit to replacing a simple, reliable back-up light switch with a back-up light switch that tells a computer to turn on the back-up lights.
Rather than watch you try to resolve issues caused by aftermarket parts with more aftermarket parts, I would recommend reinstalling the original radio to be sure everything comes back to life, then use the radio relocation kit so you can keep that radio in the truck, but out of sight. You can still put the new radio in the dash.
Dec 26, 2016 at 10:15 AM
DOODLE333
Ok thank you. I cannot find the link to one though. do you have one I can check out?
Dec 26, 2016 at 10:17 AM
CARADIODOC
  • 34,414 POSTS
I have never pursued this myself. The places to look are Best Buy, Crutchfield, and eBay. My first choice would be Crutchfield because they are all about home and car electronics and they have been around a long time. For Best Buy, I would stop in the store and talk with a salesman or one of their installers. Anything you can run into, they have addressed it before.
Dec 26, 2016 at 11:07 AM
