Remote keyless entry fob stopped working; also clock
129,000 MILES
GMEAGER
  • 5 POSTS
Both remote keyless entry fobs stopped working. New batteries didn't help. Also at the same time, the clock is not lit. Fuses for these two are OK. Would appreciate any ideas on what the problem is. Thanks.
Jul 12, 2013 at 8:56 AM
KHLOW2008
  • 41,812 POSTS
Did you check all the fuses as per diagram?
Jul 13, 2013 at 6:16 PM
GMEAGER
  • 5 POSTS
I checked two fuses, one that controls the clock, and the one that controls the remote keyless entry. Both are OK. Do I need to check every single fuse?
Jul 14, 2013 at 1:49 AM
KHLOW2008
  • 41,812 POSTS
More than one fuse is used for the circuits.You need to at least check those in diagrms.
Jul 14, 2013 at 4:40 AM
GMEAGER
  • 5 POSTS
OK, will do. Think I'll buy a fuse tester so I don't have to remove every fuse by hand. Will get back to you. Thanks for the help.
Jul 14, 2013 at 6:09 AM
KHLOW2008
  • 41,812 POSTS
Looks can be deceiving and you should be using some sort of tester, a DVOM would be good but I prefer a testlight for testing fuses.
Jul 14, 2013 at 10:33 AM
GMEAGER
  • 5 POSTS
Thanks for the suggestion on the type of fuse tester; will pick one up tomorrow.
Jul 14, 2013 at 10:47 AM
KHLOW2008
  • 41,812 POSTS
Any update on this?
Sep 14, 2013 at 2:41 PM
GMEAGER
  • 5 POSTS
I ended up taking the car in to the shop. It was a fuse under the hood; I hadn't checked for that.
Thanks for your suggestions.
Gail
Sep 14, 2013 at 2:56 PM
KHLOW2008
  • 41,812 POSTS
You're welcome.
Good luck.
Sep 14, 2013 at 3:40 PM
