remote fob no longer works
106 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
RKMJR.
  • 7 POSTS
After following your sterling advice,I swapped out the GEM module (junkyard) to get interior lighting working again. However,remote does not work anymore.I tried changing battery,and "reprogramming" (8 key turns)
By changing GEM have I lost ability to remotely open door locks? I'm not sure if there is a fuse for this feature.
Any advice would help.Thanks for your reply
rich minto jr.
Apr 1, 2016 at 11:15 PM
HMAC300
  • 48,601 POSTS
if you tried to reprogram your remote and doesn't work then you'll have to have a pro do it for you with his scanner. you only should have to one remote then others you should be able to program
Apr 1, 2016 at 11:33 PM
RKMJR.
  • 7 POSTS
Hi
As it turns out, "reprogramming" the fob DID work.After "8 turns to run,"I had to to keep key in cylinder,(in run position) while pressing the fob keys,before removing key from car.It worked!!!
Thanks for your input
LOve this site!!
Apr 2, 2016 at 8:12 AM
ED-WEEZY21
  • 248 POSTS
We are happy to hear that everything worked out for you and we look forward to answering any future questions that you may have.
Apr 6, 2016 at 10:42 AM
