Remote door lock horn not working
2005 NISSAN PATHFINDER
180,101 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
AGBOOLA SHAMUSI TUNDE
The remote still lock and open the doors but the horn that normally sound if you press the lock button to lock the doors. does not sound again while the light still flashes and secondly if one press the open button the light that normally flashes don't flash again to indicates that the door are open.
Feb 12, 2020 at 1:47 AM
  • 110,244 POSTS
I believe I know what happened. You can actually turn those functions off by holding both the lock and unlock buttons together for more than 2 seconds. So, lets do the same thing again and see if it fixes it. If this doesn't work, you will need to have a scanner that can complete the function for you.
Without CONSULT-II
When "lock" and "unlock" signals are sent from the key-fob for more than 2 seconds at the same time, the hazard and horn reminder mode is changed and hazard warning lamp flashes and horn sounds as shown.
Let me know if that helps.
Feb 12, 2020 at 10:16 AM
Thanks for the clue. the door lock system is now functioning correctly again.
Feb 13, 2020 at 12:45 AM
  • 110,244 POSTS
You are very welcome. I'm glad to see it took care of the issue you were having. I have to be honest, it isn't a difficult to have happen. It happens more often that you would think.
Please feel free to come back any time you have questions in the future.
Feb 13, 2020 at 11:46 AM
