Remote control not working
25,000 MILES • 1.5L • 4 CYL • MANUAL
DAHER YAKOUB
Remote was working sometimes. After a foolish man with a scanner tried to fix it. It's not working again. After two years of stopping the remote, my friend mechanic bought a modern scanner and brought a technical programming and I supervised the process of reprogramming the keys of the factory. The result is as follows: the scanner programmed the two keys for operation, but the wireless did not work, knowing that the scanner received the three signals from the remote.
Mar 5, 2019 at 2:22 AM
  • 55,697 POSTS
Here is the instructions for fixing the remote programming:
The key-less entry transmitters do not require a manual synchronization procedure. If needed, the transmitters automatically re-synchronize when any button on the transmitter is pressed within range of the vehicle. The transmitter will operate normally after the automatic synchronization.
Key-less Entry System Inoperative
Diagnostic Instructions
Perform the Diagnostic System Check - Vehicle prior to using this diagnostic procedure.
Review Strategy Based Diagnosis for an overview of the diagnostic approach.
Diagnostic Procedure Instructions provides an overview of each diagnostic category.
Circuit/System Description
The key-less entry system is a vehicle entry device. The key-less entry will unlock the vehicle doors or open the rear compartment when a corresponding button on the key-less entry transmitter is pressed. This is accomplished by the key-less entry transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a message over the serial data line. A low transmitter battery or radio frequency (RF) interference from aftermarket devices such as 2-way radios, power inverters, cellular phone chargers, computers, etc. may cause a system malfunction. High RF traffic areas, such as gas stations which use pay-at-the-pump RF transponders, may also cause interference that could lead to a malfunction.
Diagnostic Aids
For the J 43241 Key-less Entry Tester, inspect the key-less entry transmitter part number to determine that it is the correct model for the vehicle. See Special Tools . A wrong model transmitter may pass the test, but it will not activate the vehicle remote system.
Mar 5, 2019 at 2:30 AM
DAHER YAKOUB
When I bought the car it was brand new. This means that the keys are issued from the factory. Unfortunately, the maintenance centers were destroyed by the war. So I try to fix the problem with your help because several programmers failed to program the key. But one of them has a device to check the key. The test result was positive. I think the problem is in the receiver or the central lock module, because another problem has surfaced. Driver's side lock is blocked. When I disconnect the central lock module and connect it, the lock works several times and the problem returns.
Best regards
Mar 12, 2019 at 11:10 AM
DAHER YAKOUB
Correction: 1.6L
Mar 13, 2019 at 2:18 AM
  • 55,697 POSTS
Yep, the central lock module will need to be programmed. Here is a video of what needs to be done to confirm and fix the problem:
https://youtu.be/InIlnsjOVFA
Please let us know what you find.
Mar 13, 2019 at 3:25 AM
