My engine would run hot while idling?
218,618 MILES • 3.6L • V6 • 2WD • AUTOMATIC
HELPME87
I only had 2 relays in my vehicle. My engine would run hot while idling. So I put a relay in the 3rd place which was empty but was labeled fan 3. Now I’m not running hot but my question is this okay to do?
Jun 30, 2023 at 8:14 AM
  • 55,554 POSTS
It sounds like the relay you replaced was for the radiator cooling fans, can you confirm the fans are working by turning on the A/C system and wait about 2 minutes for the fans to come on.
This guide may help as well:
https://www.2carpros.com/articles/why-does-my-car-engine-stall-when-hot-and-how-can-i
Please go over this guide and get back to us.
Jul 1, 2023 at 5:06 AM
HELPME87
Well, I have the fan issue straightened out. Now I’m having the same issue before with it just turning off while idling or driving for a while. Replaced ignition relay. Could the crank relay play a part in this situation?
Jul 1, 2023 at 12:07 PM
  • 55,554 POSTS
Sorry, we handle one problem per thread, Please post your new question here, you must be logged in.
Cheers, Ken
Jul 3, 2023 at 5:29 AM
