Relay location and ohms ratings needed?
45,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CDINC
ABS light on and brake light. Tried swapping relays, no blown fuses, bled brakes and master cylinder where abs pump resides. I need to know the location of the ABS relay in case I missed it. I also need to know ohms rating for the wheel speed sensors.
Sep 24, 2022 at 11:18 AM
  • 110,251 POSTS
The relay is located under the hood and mounted on the firewall. See pic 1 below.
As far as checking the wheel speed sensor, here is a link that explains how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
See pic below.
Sep 24, 2022 at 4:43 PM
