Relay issues
10,000 MILES • 6 CYL • 4WD • AUTOMATIC
WESTSIDESTAR
Vehicle is stalling while in motion/driving and sometimes will not start. Been checking the battery and found a relay under where the battery goes so I cannot find any information on what is the right relays in the right spot. I will post a picture of the current relays and the relay that was found is a 4671168E 72472M. Thank you
Feb 20, 2018 at 4:22 PM
WESTSIDESTAR
Here is the picture.
Feb 20, 2018 at 4:25 PM
CARADIODOC
  • 34,414 POSTS
Does that stalling occur while you are cruising at a steady speed or only when you let off the accelerator pedal? What led you to be checking the battery? Does the engine crank normally when the no-start occurs? Have you read the diagnostic fault codes? Do you know how to do that yourself?
Feb 21, 2018 at 9:45 AM
