Relay for blower motor
162,191 MILES • 2.8L • V6 • AUTOMATIC
DHBURN39
Installed new blower motor, installed new resistor, fan would not come on. Put in a new relay, fan worked for maybe two minutes.
What could be causing the relay to go out?
Mar 10, 2017 at 12:42 PM
HMAC300
  • 48,601 POSTS
it may be the blower is drawing to many amps causing the relay to go out or there is corrosion where it hooks up. check for corrosion then use dielectric grease on prongs of relay and hook that makes for better contact. you can get the grease at auto parts for about $2.00 they have it on counter a lot of times.
Mar 22, 2021 at 7:42 AM
DHBURN39
I will try the grease.
