Relay clicking behind glovebox
200,000 MILES • 1.7L • 4 CYL • FWD • AUTOMATIC
JH8859
Replaced battery and negative cable, engine turns over but will not start. Relay behind glove box is clicking rapidly even when key is out of ignition. Relay is labeled RC-5009.
Jan 8, 2017 at 12:29 AM
HMAC300
  • 48,601 POSTS
there are five relays behind glove box. check starter control l relay and PGM relays. see picture. I would test the battery it sounds like you have low voltage? This guide will help you
Jan 8, 2017 at 2:31 AM
JH8859
Replaced the pcm relays, same result, the four pronged pcm relay is still clicking even with key removed. Would the starter control relay cause the pcm relay to rapidly click without key in ignition? Car will also not shift out of park
Jan 10, 2017 at 9:48 PM
HMAC300
  • 48,601 POSTS
check battery for condition including load test that may be problem. does car turn over and not run or just not turn over.
Jan 10, 2017 at 10:27 PM
JH8859
Battery is brand new, engine turns over but will not start,the pcm relay next to the fuel pump relay is chattering rapidly even when key is removed,I replaced both relays and same result
Jan 11, 2017 at 9:18 PM
HMAC300
  • 48,601 POSTS
This sounds like you have a bad ground somewhere? check the ground cable from the battery to the frame of the car.
Jan 11, 2017 at 9:24 PM
JH8859
Thanks for your help. Based on the dead short comment, i went back and checked all the grounding connections and found a bad ground from the fuse box under the hood. Tied in a new ground cable from the fuse box and Presto!
Jan 15, 2017 at 10:14 PM
  • 55,694 POSTS
Great find!
Thanks for using 2CarPros we are here to help. Tell a friend!
Best, Ken
Jan 20, 2017 at 12:37 AM
