Relay and fuse starter location
170 MILES • 4 CYL • 2WD • AUTOMATIC
BELLAT1
Relay and fuse starter location Please?
Aug 3, 2020 at 11:34 AM
I attached the info that you are requesting. Let me know if you need other info. Thanks
Aug 3, 2020 at 12:28 PM
BELLAT1
Hi Expert, I would like to know from the attached pictures where is the starter relay and fuse in my car listed above LE model?
Please can you crop on them?
By the way, I am not able the start my car, I have a new tested battery, the starter is also tested and working fine, I am thinking the issue is limited between the relay, fuse and ignition.
Comment :
1.The lighting is working fine in my car, including dash board, radio and all other lights.
2. No sound or sign that my car is trying to start when I turned the key-switch to start mode.
My car inspection is due in few days and would like to fix it my self with your appreciated help of course.
Thank you for your help in advance.
Aug 4, 2020 at 6:07 AM
That is a picture of the engine compartment box. The fuse is located in this box and I pointed to it, but the relay is located in the instrument panel. I attached an illustration of that one for your review.
Aug 4, 2020 at 11:48 AM
