Auto shut down relay location needed
37,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
JESTEP1966
  • 9 POSTS
does anybody know where auto shut down relay is located? is it inside the driver side fender weld?
Nov 4, 2020 at 8:34 AM
STEVE W.
  • 15,399 POSTS
It is inside the power center (under the hood fuse panel) mounted on the circuit board if the information is correct. Not a replaceable part without taking the power center apart. However there is also the power relay that does a similar job and it is a replaceable item inside the relay box.
Nov 4, 2020 at 9:15 AM
Good evening,
I attached the location for you to view.
It is in the power distribution center under the hood.
Nov 4, 2020 at 9:17 AM
