relay to solder in I would like to bypass?
180,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
VERNON3281
i've pulled out my fuse box and identified relay 302 as being bad. This relay is intergraded into the central junction box/fuse box and since i don't have a relay to solder in I would like to bypass with external one. i just need to know what pigtail and wires i need to splice into, thank you
May 14, 2023 at 5:34 AM
  • 55,627 POSTS
We do not show the relay 302, can you tell me what it goes to? It should say in the fuse panel cover by location.
May 15, 2023 at 5:10 AM
VERNON3281
it's for the heated PCV valve but i believe other stuff is on it also 2005 expedition now 2003 relay 302 is for something else but its inter graded in to fuse box in between the 6 big relays is a gap if you look in between you will see the top of 5 mini relays i wanted to bypass with external relay like i see people do for fuel pump relay which is mini relay next to it I'm going to try ordering a manual to get schematics to figure out.
May 15, 2023 at 11:58 AM
