Hard starting of engine
172,305 MILES • 4 CYL • FWD
ALBERT A. SENGE
The car starts developing the problem of hard starting two days ago. I will have to try at least three times, and when it eventually starts, it will be very slow until after five to ten minutes before it partially stabilizes.
May 31, 2017 at 4:41 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge in US auto parts rent it see our link. it may be low fuel pressure causing hard starting if not at minimum pressure gives problems.
May 31, 2017 at 11:42 PM
