Regulator motor
111,000 MILES • 0.6L • 6 CYL • 2WD • AUTOMATIC
ELIZABETH MOHSEN
I took motor apart now i can't fit that gear that has to be greased connected to the cables. i can't fit it back into the silver casing to close it.
Aug 11, 2019 at 1:07 AM
Hi Elizabeth,
Can you send me a picture of what you are working with? because the way I understand it, I think the issue is the motor is not serviceable. Meaning if you take it apart it is not meant to be and is very difficult if not impossible to go back together. However, seeing it will help because I could be way off.
Let me know and we will make your regulator great again. :)
Aug 11, 2019 at 3:51 AM
