When starting the car and the engine is cold it idles normal and revs up to 2,000 rpm's then shuts off but when engine is hot it drives like normal.
Jul 2, 2019 at 7:03 PM
✓Experienced Mechanic
It sounds like you may need to service the throttle bore or have a coolant sensor not working correctly. To be sure lets run the codes to see whats comes up. here is a guide:
