Refilling Freon in air conditioning
180,000 MILES
J WIRTHLIN
The Freon will come not go in.
Aug 16, 2020 at 11:14 PM
  • 110,248 POSTS
Is the A/C turned on high and the engine running when you do it? Are you using a reusable gauge that may not have punctured the top of the can?
Here is a link that explains how it's done. See if you missed anything.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Next, I need to know if the ac is working at all, if it just stopped, what type of system you are using to charge it and anything you can think of that may help me with a diagnosis.
Aug 17, 2020 at 1:19 PM
94 TRANSAM
  • 680 POSTS
First you need to make sure you are putting it in on the low pressure port not the high. Make sure the car is running. Make sure you have the right hose connector for the port. Make sure the button inside the head of the hose is there or the shrader valve wont open to let the gas in. Here is a guide to help:
Let me know how it works out.
Rich
Aug 17, 2020 at 1:23 PM
