Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Sentra
Engine
Symptoms
Vibration
Reeve counter vibrating when car idle
1995 NISSAN SENTRA
245,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
CLEMENCE KUNAKA
MEMBER
1 POST
R counter not stable when car idle, above 1000rpm and below upon take off gauge vibrate from 1000rpm to 2000rpm then normal from 3000rpm
Aug 9, 2014 at 7:25 PM
HMAC300
Experienced Mechanic
clean throttle plate with choke cleaner on both sides and iac hole then check for a vacuum leak like bad hoses cracked etc.
Aug 10, 2014 at 1:57 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
