reduced engine power light on
206,000 MILES • 4.2L • V6 • 4WD • AUTOMATIC
TWISITED SOUL
My vehicle will not go over 15 MPH using a lot of gas. yes, the reduced engine power light came on also I don't have any codes on it. My husband changed the throttle body and plugs. My sister has an Envoy she said hers done the same thing, and it ended up being one of the coil packs.
May 13, 2022 at 8:29 PM
This could be a coil issue, so we need to start by checking the codes and finding out what is there so that we are not guessing.
So, if we are going to see if this is a coil then we need to check for spark.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Basically, we need to start with codes because there are a number of things that can cause this.
However, if the coil checks out then we need to check fuel pressure and I am sure by then we will have a better idea what direction to go.
https://www.2carpros.com/articles/reduced-power-limp-mode
Let's start with this info and go from there.
Thanks
May 15, 2022 at 1:03 PM
