Error code "reduced engine power"
267,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
MONKNICKLES
While driving I get error code"Reduced engine power " and car slows down to twenty mph.
Aug 23, 2018 at 11:29 PM
Good morning.
This code appears when there is an issue with the fly by wire system for the fuel pedal.
I would check the connector at the throttle body. It is a common failure for this issue.
Did anyone check for codes? There is a code stored in the system and that will help narrow the area of failure.
Aug 24, 2018 at 1:03 AM
RENEE L
  • 1,260 POSTS
Hello MONKNICKLES,
If you decide you would like to conduct the scan yourself here is a link to an article from this site that features written step by step instructions and pictures explaining how to do the scan yourself. Also, I have included a link to our YouTube channel with a how to video on code scanning.
This is applicable even if your check engine light is not on.
Most scanners are inexpensive to purchase, you can purchase one online from sites like Amazon.com
https://youtu.be/YV3TRZwer8k
Once you have the codes please get back to us with the code number(s) so that we can further assist you. We are always happy to help.
Thank you for visiting 2CarPros.com.
Kindest regards,
Renee
Admin
Aug 24, 2018 at 3:23 AM
