Reduced engine power
206,000 MILES • 4 CYL • AUTOMATIC
SANDRAG
About a month ago the reduced engine power light came on and I couldn't drive over 15 mph. Before that happened my car was cutting back on speed and cutting off when I would stop at a light or slowed down almost stopping. I know that I need 2 sensors but the guy at AutoZone said that those sensors wouldn't make the engine reduce power. I'm a woman so I don't know much about cars so I am trying to find some advice so that when I take it in to be fixed I won't feel like I'm being taken advantage of by someone telling me that I need more done than I actually do. My car has also had a lot of modifications done by the previous owner and I think that it was used to race at some point. Any advice will surely be helpful and appreciated. Thank you.
Nov 19, 2019 at 12:31 PM
Good morning,
Did the parts store check for any codes? If they did, can you give me the code numbers? You have a throttle body and a fuel pedal that are a big part of the system that gives you this message.
https://www.2carpros.com/articles/reduced-power-limp-mode
Nov 19, 2019 at 7:13 PM
SANDRAG
Hi Roy. Yes, but this was way before the reduced engine power after that I couldn't drive the car. I don't have the codes but at the Chevrolet dealership this is what I was given. Mass air flow sensor, r&r OEM (J5670). I hope that this helps.
Nov 19, 2019 at 7:48 PM
No, the mass airflow has nothing to do with reduced power.
Did they give you any other information?
Nov 19, 2019 at 7:56 PM
I got an email with a response but nothing came up.
Did you respond?
Nov 20, 2019 at 1:52 AM
