Reduce power light and check engine light comes on
145,400 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
POWERCURBER
Both lights come on and i have to pull over. I shut the car off wait two minutes and start it again lights are gone, but returns five minutes later. The car also jerks when you keep it a constant speed. I Cleaned the throttle body and replaced the valve cover gasket. But still have the same problem.
Apr 7, 2017 at 1:21 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent gauge. return with results. should be 50-60 psi key on only, see link.
Apr 8, 2017 at 12:51 AM
