While driving car will reduce power and traction light and check engine light will come. Gives a code of throttle body but already replaced it.
Sep 11, 2017 at 8:53 AM
✓Experienced Mechanic
First off, thank you for your service. Can you give me the code number please? You might have a wiring problem or a throttle pedal position sensor can be out. I need the code number to move forward.
