Red wrench light and transmission not shifting properly
150,000 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
IBLASHAUN
  • 17 POSTS
takes off fine reverse works just does not want to go 2nd to 3rd unless let off gas.
Jul 16, 2020 at 11:36 AM
  • 110,248 POSTS
The red wrench light is indicating there is at least one diagnostic trouble codes stored in the computer network. Because of the model year, I recommend having the vehicle's CAN bus system scanned. CAN stands for computer area network. Basically all the modules / computers work in conjunction with each other. If you have the CAN system scanned, it should point to where the problem is coming from. Here is a quick video showing how and why it's done:
https://youtu.be/InIlnsjOVFA
If you have no access to a scan tool that can read the can bus system, try to get your hands on a traditional scan tool to try and retrieve codes. Once you do that, let me know what you find and I will be better able to direct you.
Here is a list of OBD2 codes which are relevant to your vehicle:
https://www.2carpros.com/trouble_codes/obd2
Let me know if this happened all at once, if you noticed something happening, or anything you can think of that may help me diagnose the issue.
Also, if you haven't already, make sure the transmission fluid is clean and full. Here are the directions for testing and preliminary checks. The attached pic correlates with these directions.
_________________
2010 Ford Focus L4-2.0L
Preliminary Inspection
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Testing and Inspection Initial Inspection and Diagnostic Overview 4F27E - Automatic Transmission Preliminary Inspection
PRELIMINARY INSPECTION
307-01 Automatic Transaxle/Transmission — 4F27E 2010 Focus
DIAGNOSIS AND TESTING
The following items must be checked prior to beginning the diagnostic procedures:
Know and Understand the Concern
In order to correctly diagnose a concern, first understand the customer complaint or condition. Customer contact may be necessary in order to begin to verify the concern. Understand the conditions as to when the concern occurs, for example:
Hot or cold vehicle temperature
Hot or cold ambient temperature
Vehicle driving conditions
Vehicle loaded/unloaded
After understanding when and how the concern occurs, proceed to verify the concern.
Verification of Condition
This section provides information that must be used in both determining the actual cause of customer concerns and executing the appropriate procedures.
The following procedures must be used when verifying customer concerns for the engine.
Determine Customer Concern
NOTE: Some transaxle conditions can cause engine concerns. The Torque Converter Clutch (TCC) not disengaging will stall the engine.
Determine customer concerns relative to vehicle use and dependent driving conditions, paying attention to the following items:
Hot or cold vehicle operating temperature
Hot or cold ambient temperatures
Type of terrain
City/highway driving
Upshift
Downshift
Coasting
Engagement
Noise/vibration — check for dependencies, either rpm dependent, vehicle speed dependent, shift dependent, gear dependent, range dependent or temperature dependent.
Transmission Fluid Level Check
NOTICE: The vehicle should not be driven if the transmission fluid level is below the bottom line on the transmission fluid level indicator and the ambient temperature is above 10°C (50°F).
NOTE: Transmission fluid expands when warmed. To obtain an accurate transmission fluid level check, drive the vehicle until normal operating temperature is reached, approximately 32 km (20 mi).
NOTE: If the vehicle has been operated for an extended period at high speeds, in city traffic, during hot weather or while pulling a trailer, the vehicle should be turned OFF for approximately 30 minutes to allow the transmission fluid to cool before checking.
NOTE: Incorrect level may affect the transaxle operation and could result in transaxle damage.
Under normal conditions, there is no requirement to check the transmission fluid level. However, if the transaxle is not functioning correctly, the transaxle may slip, shift slowly or there may be some sign of transmission fluid leakage, the transmission fluid level should be checked.
Drive the vehicle 30 km (19 mi) or until the vehicle reaches normal operating temperature.
Park the vehicle on a level surface and engage the parking brake.
With foot on the brake, start the engine and move the selector lever through all the gear ranges. Allow sufficient time for each gear to engage.
Place the selector lever in PARK and leave the engine running.
Remove the transmission fluid level indicator and wipe it clean with a lint-free cloth.
Install the transmission fluid level indicator, making sure that it is fully seated in the filler tube.
Remove the transmission fluid level indicator. The transmission fluid should be within the designated areas.
See pic 1
Item Description
1 Maximum transmission fluid level
2 Normal operating transmission fluid level range 49°C-60°C (120°F-140°F)
3 Minimum transmission fluid level
High Transmission Fluid Level
A transmission fluid level that is too high may cause the transmission fluid to become aerated due to the churning action of the rotating internal parts. This will cause erratic control pressure, foaming, loss of transmission fluid from the vent tube and possible transaxle damage. If an overfill reading is indicated, adjust the transmission fluid to correct level.
Low Transmission Fluid Level
A low transmission fluid level could result in poor transaxle engagement, slipping or damage. This could also indicate a leak in one of the transaxle seals or gaskets.
Adding Transmission Fluid
NOTICE: The use of any other type of transmission fluid than specified could result in transaxle damage.
If transmission fluid needs to be added, add transmission fluid in 0.25L (1/2 pt) increments through the transmission filler tube. Do not overfill the transmission fluid. For transmission fluid type, refer to specification in this section.
Transmission Fluid Condition Check
Check the transmission fluid level.
Observe the color and the odor. The color under normal circumstances should be a dark red color, not brown or black or have a burnt odor.
Hold the transmission fluid level indicator over a white facial tissue and allow the transmission fluid to drip onto the facial tissue and examine the stain.
If evidence of solid material is found, the transmission fluid pan should be removed for further inspection.
If transmission fluid contamination or transaxle failure is confirmed by the sediment in the bottom of the transmission fluid pan, the transaxle must be disassembled and completely cleaned and clean the transmission fluid cooler tubes and transmission fluid cooler.
Carry out diagnostic checks and adjustments. Refer to Diagnosis By Symptom in this section.
If the transaxle is to be overhauled or if installing a new transaxle, the transmission fluid cooler must be backflushed. Refer to Transmission Fluid Cooler Backflushing and Cleaning in this section.
Water in Transmission Fluid
To correctly repair an automatic transmission or transaxle that has had water or coolant introduced into the system, completely disassemble, clean and replace the following parts:
All internal and external seals
All friction material; clutches and bands
Torque converter
All parts with bonded seals
All solenoids
All transmission fluid filters
Prior to installing the transmission or transaxle, the transmission fluid cooler(s), transmission fluid cooler tubes and transmission fluid cooler hoses need to be flushed and cleaned.
Jul 16, 2020 at 1:24 PM
IBLASHAUN
  • 17 POSTS
Sorry took so long to get back to you, lot going on. First id like to say i found out that friend put ABS sensor in backwards. So there is a start Also i believe i told you first can reading said shift solenoid D stuck on. So went to Reds transmission bought D and replaced it then friend switched with another that looked the same still comes back d stuck on. i have spent a lot of time and something (besides the ABS) i have found is the wheel speed sensor. i say this because of the shifting engine revving up if let off gas it goes ahead and shifts. i am going to take to AutoZone to test can maybe i am not using it right.
Jul 26, 2020 at 1:58 AM
  • 110,248 POSTS
Are you planning to have the computer scanned for codes? I don't know if a parts store can scan the CAN BUS system.
Jul 26, 2020 at 7:03 AM
