Red light comes on then the car stops and won't crank until it sits a while then cranks and drive.
May 19, 2025 at 11:32 AM
✓Experienced Mechanic
This light is known as the "master warning light" and most of the time when this comes on there is a problem with the hybrid battery. To be sure we should do a CAN scan which will give us the code to help confirm the failure.
