Red parking brake letters?
79,900 MILES • 4 CYL • 2WD • AUTOMATIC
SOOP78
Engine light came on. ABS light. Parking light. Says parking brake, see Operators manual in red. Steering became stiff suddenly. All lights turned off once and steering was normal. They came back on, and the steering is stiff. Says parking brake. Even though it's not engaged. Says ABS and picture of car with slick strips on too.
Oct 31, 2024 at 1:36 AM
  • 55,711 POSTS
That is a good one, it sounds like the electric power steering is going out or the spiral wire (clock spring) behind the steering wheel has a bad connection and the car goes into limp mode, the best thing to do at this point is a CAN scan which is easy to do. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please upload videos in your response of any problems so we can see what to help you with.
Oct 31, 2024 at 10:35 AM
