Red light does not go off when attempting to start the car
2005 FORD IKON
223,965 MILES
BULELANI MBEKENI
I have the vehicle listed above and it doesn't start. when I switch on, the light under the clock shows solid red and it indicates after. what could the problem?
Jan 27, 2021 at 10:09 PM
Good morning,
Is the light for oil pressure? If it is, make sure you check the level.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
If the level is okay, then I would have a manual oil pressure test performed to determine why there is not enough pressure.
Jan 27, 2021 at 10:37 PM
