Leaking red fluid
1989 FORD BRONCO
240,000 MILES • 2.9L • 4 CYL • 4WD • MANUAL
TAMMY7403
I have a five speed Bronco ll. It is leaking red fluid underneath. What can that be? I've had it worked on for getting stuck in gear.
Jan 1, 2019 at 3:04 AM
Good afternoon,
It could be from the transmission. the five speeds are common for using transmission fluid.
Has anyone looked at it to see where it is coming from?
https://www.2carpros.com/articles/how-a-standard-transmission-works
The top gasket, the front cover gasket and the rear seal are common areas for leaking.
Jan 1, 2019 at 6:19 AM
