How to re-coding ignition switch
150,000 MILES • 2WD • AUTOMATIC
HELENFREE1
I replaced the ignition switch car won't turn on now so I got a code to re-coded but I don't know how to re-code.
Mar 26, 2020 at 7:28 AM
  • 110,246 POSTS
I wish I had an easy answer for you that could be done at home, but this requires software to do . Take a look at this:
The WIN initialization procedure is required whenever the WIN or shaft lock module is replaced on vehicles equipped with the shaft lock module. (wireless ignition node)
Was it only the switch that was replaced?
Mar 26, 2020 at 8:20 AM
