Re-circulation actuator
186,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
GEORGE A R
Took the old one out and glued the gear together. Hooked it up to see if it works (not mounted just connection). It only turns one way. Can't get it to turn the other way.
Feb 20, 2019 at 3:20 AM
Good evening,
What mode door? Blend door or modes?
Do you have auto climate control or manual?
Feb 20, 2019 at 7:41 AM
GEORGE A R
Recirculate. Fresh air. Manual control.
Feb 20, 2019 at 7:56 AM
Okay, there is no motor for re circulation. there are only two motors, one for temperature control and one for mode door operations.
Can you post a picture of what you see?
Feb 20, 2019 at 8:11 AM
