Recent Squeaky Noise After Cold Start on Almost New Van
24,800 MILES • AUTOMATIC
MOUNTAIN123PEAK
  • 77 POSTS
I have a 2010 Honda Odyssey EX, which a mechanic said was in very good condition, and I recently noticed that after every cold start, there is a squeaky noise. This squeaky noise isn't always there, only when I start the van after it hasn't been used for at least a few hours. It rained recently, and I also hit two very deep potholes. Could the problem be because a belt now needs adjustment?
Can you please tell me how much I should expect to pay in order for a shop to adjust the belt? Can you also tell me how much I should be expected to pay to replace a belt? Thanks.
Jan 13, 2014 at 4:57 AM
SATURNTECH9
  • 30,868 POSTS
Here's the problem don't know if it is a belt or if it is which belt?I could just give you a price for a belt but dont know which belt or if it is a belt.Whats your zip code?
Jan 13, 2014 at 5:32 AM
MOUNTAIN123PEAK
  • 77 POSTS
Thanks for your reply. I ended up going to the mechanic and after doing an inspection, he put some lubrication and told me I shouldn't worry and that it would clear up, and it has!
Jan 21, 2014 at 2:01 AM
SATURNTECH9
  • 30,868 POSTS
So just lubed the belts ?Were the belts cracking?
Jan 21, 2014 at 4:11 AM
MOUNTAIN123PEAK
  • 77 POSTS
The mechanic said that the only thing that looked like a problem was some rust near the A/C clutch, and that he lubricated it. It made some noise the morning after, and I asked him about it again. He said it was humid and it would eventually clear up. I think the problem might've been that the van was driven only once a month from September to October. So rust might've built up.
Jan 21, 2014 at 6:51 AM
SATURNTECH9
  • 30,868 POSTS
Also pulley grooves get belt material etc in them and make noise.
Jan 21, 2014 at 7:23 AM
MOUNTAIN123PEAK
  • 77 POSTS
Do shops remove belt material from the pulley grooves if it's there, or is the presence of material in pulley grooves a sign that the belt needs to be replaced?
Jan 21, 2014 at 8:16 AM
SATURNTECH9
  • 30,868 POSTS
Its just a little trick I have used for a lot of years with squeaky belts.You can call around and see works good.I replace belts when they start cracking.
Jan 21, 2014 at 8:25 AM
