Recent slight overheating?
100,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MSKFSH
  • 7 POSTS
So, I have noticed that recently, my car's coolant temperature increases briefly 1 notch above normal operating temperature especially when idling and only when the AC is off. The coolant was flushed not long ago and looks very clean. I did burp the system yesterday and it released some bubbles, but the problem persisted. The thing that confuses me the most is why don’t the fans kick in earlier? I verified that they kick in both but only when the car overheats as described above or when I turn on A/C! Isn’t it supposed to kick in based on feedback from the temperature sensor? I checked my car model, and I don’t think it has a dedicated coolant fan switch.
Can it be the thermostat? This particular model has 2 of them! But then again, why wouldn’t the fans kick in in time if the sensor is reading the high temperature?
It’s interesting to mention that I also noticed that it takes a bit longer than before to reach the operating temperature when I first drive it in the morning.
So, in short, the car slightly overheats, fans kick in too late, but when they do the temperature goes down.
Jan 21, 2024 at 5:24 AM
  • 55,721 POSTS
Yep, this car has two engine coolant temperature sensors and the TIPM sends power to the fans to have them turn on. I have seen both the sensors and the TIPM fail and cause this problem. Here are the cooling fan wiring diagrams so you can check it out, also if you have a scanner, you can see the engine temperature as the computer is seeing it which might tell us the coolant sensors are bad off slightly. Also, you might have a trouble code stored in the system.
Here are the locations of the coolant sensors, also I would check the thermostat as well, if you have one stuck open it can mess up the system.
Please go over this guide as well:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Check out the images (below). Let us know how it goes.
Jan 22, 2024 at 2:59 AM
MSKFSH
  • 7 POSTS
I have a very basic scan tool and there is no check engine light. I am surprised by the other sensor ! I’m going to use my very basic code reader and what I get. You think if I change the 2 sensors and thermostats, I can solve this issue?
Jan 22, 2024 at 5:05 AM
  • 55,721 POSTS
Yep, it should fix it but let me know what codes you get if any.
Jan 23, 2024 at 2:11 AM
