Rebuilt transmission acting strange again
73,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
COOLOLDS85
  • 173 POSTS
I just got my transmission rebuilt in June. The car is doing the same thing again but a little worse. When I put the car in reverse today it wouldn’t go into reverse. I know I had it put into the gear. It took me 3 try’s to get it into reverse for the car to move backwards. I also notice at a stop light, when I began to accelerate it started jerking when in drive. It’s not whining like it did before. Just doing the following symptoms.
Do you think the place I took it to put the parts in wrong or are defected? I know something like this happens when a transmission is rebuilt. But this isn’t used, it has all new clutch packs put into it.
Sep 21, 2019 at 2:21 AM
Good afternoon,
You should have a warranty on the repair. All the shops I deal with have 6-month warranties.
Did you check the fluid level? A low fluid level could cause this.
Are there any codes stored for the fault?
Sep 21, 2019 at 6:47 AM
COOLOLDS85
  • 173 POSTS
No codes, level is good. the shop has closed now. So i don't think the shop i take it to will honor the plan because the part I am thinking that needs to be replaced wasn't replaced from the location I took it to.
Sep 21, 2019 at 6:56 AM
You will need someone to check it for you.
Yes, it sounds like it may have to be opened up again.
Sep 21, 2019 at 7:27 AM
