Reattach high pressure line to power steering pump tips
200,000 MILES • 3.4L
JPATER01
having trouble realigning high pressure line to reattach to power steering pump after replacing camshaft position sensor. Any tips on this process?
Mar 15, 2020 at 10:24 AM
  • 110,246 POSTS
Here are the directions for removal and replacement of the high pressure hose. See if anything helps. If it doesn't, let me know.
___________________
2001 Chevrolet Impala V6-3.4L VIN E
P/S Pressure Hose Replacement
Vehicle Steering and Suspension Steering Power Steering Power Steering Line/Hose Service and Repair Procedures P/S Pressure Hose Replacement
P/S PRESSURE HOSE REPLACEMENT
Power Steering Pressure Hose Replacement (3.4L)
Removal Procedure
1. Place a drain pan under the vehicle.
pic 1
2. Remove the power steering pressure line from the power steering pump.
3. Remove the power steering pressure line from the power steering lines retaining bracket on the engine.
pic 2
4. The power steering pressure line is the lower line at the power steering gear.
Remove the power steering line from the power steering gear using an 18-mm crow's foot line wrench with a 2-foot long, 3/8-inch drive extension. Access the line from the engine compartment, between the rocker arm cover and the front of the dash mat.
5. Raise and suitably support the vehicle. Refer to Vehicle Lifting.
pic 3
6. Remove the power steering pressure line (1) from the clamps on the power steering gear.
7. Remove the power steering pressure line (1) from the vehicle.
Installation Procedure
1. Install the power steering pressure line (1) to the vehicle.
pic 4
2. Install the power steering pressure line (1) to the clamps on the power steering gear.
3. Lower the vehicle.
Notice: Refer to Fastener Notice in Service Precautions.
pic 5
4. Install the power steering pressure line to the power steering gear.
Use a 18 mm crow's foot line wrench with a 2 foot long, 3/8 inch drive extension.
Tighten the power steering pressure line fitting to the power steering gear to 27 Nm (20 ft. lbs.).
5. Install the power steering pressure line to the power steering lines retaining bracket on the engine.
pic 6
6. Install the power steering pressure line to the power steering pump.
Tighten the power steering pressure line fitting to the power steering pump to 27 Nm (20 ft. lbs.).
7. Fill the power steering system with power steering fluid. Refer to Checking and Adding Power Steering Fluid.
8. Bleed the power steering system. Refer to Bleeding the Power Steering System.
9. Inspect the power steering system for leaks. Refer to Power Steering Fluid Leaks.
____________________________
Mar 15, 2020 at 10:45 AM
JPATER01
I am having trouble aligning high pressure line to reattach at the power steering pump. any tips on how best to do that and realign and attach at power steering pump?
Mar 15, 2020 at 11:40 AM
  • 110,246 POSTS
There really isn't a specific procedure for this. If you loosen the pump, do you feel it will make it easier? If possible, take a picture of what you are dealing with so I can see it. I may see what is causing the issue.
Mar 15, 2020 at 12:02 PM
