Rear washer fluid pump and rear wiper are not working
190,000 MILES • 2WD • AUTOMATIC
AARMITCH
I suspect a blown fuse, but I'm not sure which one to pull. Any help is appreciated.
Sep 20, 2019 at 9:56 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It is located in the RAM (rear area module). Here is a tutorial showing how to replace fuses:
I've attached two pictures below showing the locations.Hope this helps and thanks for using 2CarPros.
Danny-
Sep 20, 2019 at 10:17 AM
AARMITCH
Thanks for the quick response. It didn't end up being the fuse. I've been able to get the wiper to travel in 1 direction, but then it stops and makes a loud clicking that only stops when the key is pulled from the ignition. Ideas?
Sep 20, 2019 at 1:10 PM
DANNY L
  • 5,648 POSTS
Hello again.
In that case since fuses are good, Sounds like the actual wiper motor is defective. I've attached step-by-step instructions for removal. I've also attached a picture of the Kia factory part number.You can save a money by going to your local auto parts store if you want a non factory part.Hope this helps and thanks again for using 2CarPros.
Danny-
Sep 21, 2019 at 12:18 PM
