Rear window tint removal
120,000 MILES
STARLORD1976
  • 173 POSTS
Can I use a plastic scraper to remove tint from rear window without damaging the defroster lines? Tint is so old, I can’t tear it off in one piece. I'm using steam.
Sep 8, 2020 at 12:01 AM
STEVE W.
  • 15,372 POSTS
Those lines are really easy to damage. With steam you can just keep using the steam to soften the glue and the tint should peel off, then use the steam to remove the glue with a towel. The catch with using a scraper is that you can cause a tiny scratch which is enough to stop the grid from working. However there are kits that let you repair that type of damage.
Sep 8, 2020 at 1:37 AM
STARLORD1976
  • 173 POSTS
Is the defroster lines made inside the glass?
Sep 9, 2020 at 2:47 AM
STEVE W.
  • 15,372 POSTS
No, there are actually just thing lines of resistance paint that is applied to the glass. When battery power is applied to the ends of the grid they warm the area around them. That is why they are easy to damage, the lines are very thin and even a small scratch will make them stop working.
Sep 9, 2020 at 4:13 AM
