Rear window drivers side does not work
126,780 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
BARRY MOORE
Replaced rear window regulator and still does not function.
Mar 15, 2019 at 9:47 PM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with your vehicle's Body Control Module (BCM). Your vehicle's BCM, which is located behind the left side of the dashboard, is responsible for supplying power to the power windows and the power door locks. If the internal circuitry for rear window regulator has failed, no power will make it to the window motor. I have included in the diagrams down below a wiring diagram of your vehicle's power window circuits. Could you do me a favor and check out both the connectors, pins in the connectors and the wire that I have highlighted in yellow. Please get back to us with what you find out.
Thanks,
Alex
2CarPros
Mar 15, 2019 at 10:05 PM
