Rear wheel speed sensor location and replacement instructions needed
60,000 MILES • 2WD • AUTOMATIC
KAYLADICKEY3
My mother-in-law's car listed above has a bad rear wheel speed sensor or ABS whatever it's called. I can't find where it's located and how to change it. I just need a location on where to look and how much work to change it.
May 21, 2022 at 1:16 AM
SQM
  • 6,383 POSTS
The wheel speed or ABS sensor is located in the wheel hub.
I have attached a diagram below for your reference.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Let me know of any questions.
May 21, 2022 at 1:38 AM
KAYLADICKEY3
Do I need to remove anything from the cargo area to access the plug or is the connector underneath the car? I know on some vehicles are inside the trunk somewhere.
May 21, 2022 at 2:20 AM
SQM
  • 6,383 POSTS
This will need to be accessed from under the vehicle. You will see the wire coming out of the back of the hub behind the wheel.
May 21, 2022 at 4:05 AM
