Rear wheel grinding
127,000 MILES • 6 CYL • FWD • AUTOMATIC
MWEST.MW65
When I make a left hand turn my right rear wheel makes a grinding noise when the car straightens out and I am going straight down the road the grinding stops.
May 3, 2017 at 12:49 AM
HMAC300
  • 48,601 POSTS
check your wheel bearing on that side it is probably bad and in need of replacement.
May 3, 2017 at 2:35 AM
  • 55,770 POSTS
If the wheel bearing on that side it is bad it will allow the drum to contact the backing plate causing the grinding noise you are describing.
Here is a guide that will show you how to replace the bearing.
https://www.2carpros.com/articles/how-to-replace-front-wheel-bearings-and-seals
Cheers, Ken
May 3, 2017 at 1:50 PM
