How to remove the axles?
150,000 MILES • 6.6L • V8 • 2WD • MANUAL
CHARLES WILBUR
  • 10 POSTS
how do i pull the axels on a 12 bolt posi to do rear wheel bearings?
Sep 1, 2024 at 9:19 AM
CHARLES WILBUR
  • 10 POSTS
update - i got the axels out ( no c-clip)
My next question is how do i pull the old bearings off the axel ?
Sep 1, 2024 at 9:50 AM
  • 110,248 POSTS
Great Car!!! My best friend had a W31 that I believe was the same year.
As far as the bearing is concerned, it should be mounted in the axle tube. Take a look through this link. It is on a truck, but the idea should be the same.
https://www.2carpros.com/articles/rear-axle-seal-replacement
Page down to steps 4 or 5. Step 5 discusses the bearing and seal replacement procedures. If you watch the video in step 4, it explains the entire process which may help.
Sep 1, 2024 at 1:35 PM
